Australian - Aus Residential Window object
Elemental_BD
Does anyone know which library this object belongs to? And how I can procure it?
5 REPLIES 5
Miha_M
Difficult to figure out by "Residential window" name only. Could you attach a picture or better description?
Maybe it belongs to the ssa AUS essential library?
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Lingwisyer
Guru
From the CI Essential Library? If you have a SSA you should be able to log into the MYCI portal and download the library from there.
Ling.
Elemental_BD
Thanks - per your suggestions, I think that is correct, it's part of the Aus Essential/MYCI library.
I don't currently have an SSA so will need to upgrade... 😞
Lingwisyer
Guru
Is there some feature of this window that you need that you cannot achieve with the default windows?
Elemental_BD
The ability to have a header material above the window that is different to the wall is the critial element.
Learn and get certified!
