AxB size presented different in dialog box & info pallet
I have modified AxB size from info pallet & it's correct with drawing. The problem is that in dialog box for same library object the AxB size is presented different (is the before-last one).
2 REPLIES 2
Just to be clear - you change the values in the info box and then you opened the settings dialogue and they showed the old or default values?
If this is the case all I can think of is that you may have two basins selected - each with different values of which only one set of values will show.
Otherwise if you are changing the values in the object settings dialogue then the info box settings will not change untill you press OK.
Thank's for reply Barry,
Yes, old values where shown.
No, only one basin was selected while dialog box was opened. But the values from info box where changed for multiple basins to bring them to same size.
Sure
Learn and get certified!
