Beam Hole Desactivated
sma4bim
Hello the community,
I have another problem.
I need to design a beam with one or multiple hole(s), but the option is Desactivated.
Even in the pet palette .
Do someone have a solution please ?
sma4bim
i just need to switch to the plan view and create it.
sma4bim
or.... snap the opening tool on whatever plane of the beam you would like in the 3D window, section or elevation...
AC 7-26 (current 25/26)
iMac 3.6 Ghz 10Core Intel Core i9 / 12b GB / AMD Radeon Pro 5700 XT 16 GB / Ventura 13.4
https://globularcreative.wixsite.com/home
