Brick bonding on Archicad
is there a way to do a brick bonding plan on archicad? when i need to use structural wall on my projects i always do it manually, but i would like to know if there is a way to do it faster with parameters or something. i already searched for this topic but i couldn't find anything - or maybe i just don't know how to write it correctly to find something. thank you!
ps: i'm not sure if the sentence is correct, since english is not my first language. what i mean to say is how to do this:
11 REPLIES 11
Erwin wrote:
Ouch, talk about billable hours for producing drawings like that
If I well remember there is/was a say in Brazil that is something like this: "What is a fart, when you are all cover in sh*t"
vdentello
vanessa-santos wrote:
vdentello wrote:
I do it with GDL objects and the Array function. Coding all the blocks in a single element makes it harder for "decisions" like wall joinings.
Plus, it won't allow easy selection of individual blocks for mapping like I had to do.
yes!! this is what i usually do when i need to use structural walls on my projects. i just thought that maybe there would be a solution using the property manager or something that would make my life easier haha but i guess it can't be helped. at least doing it one by one can be a really good way to learn some things about building practice.
It won't take that long!
The main issue is: stick to the grid. When we do these projects we never do anything in-between 15 or 12,5 which is the block modulation. Then it's just multiplying and doing the changes needed. For example, a batroom has 120 or 135 inside. It will be sized in modular increments.
These are fairly low-cost houses, every custom block tends to be add a managing issue, so, the simpler, the better.
That's the saying!
Could be "If you're in the rain, you know you're about to get soaked. So, just go on", that's more SFW but same meaning. There are a couple more
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
