Design forum
Building pad
Polar Bear
Is there a quick and easy way to create building pad without having to transform the original topo (creating a copy, layer etc...) (similar to revit building pad fonction).
Thanks a lot!
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Oleksandra Vakariuk
Hi there,
You can use Solid Element Operations (Select an Element > Right Click > Connect > Solid Element Operations) with your foundation slab, or create a slab to fit the shape you want and put it on a hidden layer. The Operation you need is Subtraction, the slab will be an Operator, and the mesh will be a Target. Later on, you can edit the slab and the change will be reflected in the mesh.
Oleksandra Vakariuk
Customer Engagement Trainee
Oleksandra Vakariuk
Hi there,
Oleksandra Vakariuk
Thanks a lot
Archicad 25 - 5010
Didn't find the answer? Start a new discussion
