Design forum
COLORS DISPLAYING IN FLOOR PLAN
Some what new to Archicad but picking it up. Would like to see black and white display of elements but getting a few colors showing up. This is a floor plan created using hotlink modules of the units. Would like to see black entirely.
jakubc7
You need to adjust your PENS. Check what PEN # you are using and change them to BLACK. Assign that "pen set" to the VIEW that you place on your SHEET.
OPTIONS > ELEMENT ATTRIBUTES > PENS AND COLOURS
It's common practice to have number of pen sets.
At minimum have one that you work with within ArchiCAD ... I like to know that RED is 0.18mm thick, BLUE 0.25mm, GREEN 0.50mm etc ... it's easier to tell them apart than if everything is black and white.
Then you have a second PEN SET for you PDF publishing, with just blacks and greys etc.
Hope this makes sense.
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
Rod Jurich
jeffreyarch wrote:
/.........Would like to see black entirely.
You could also leave your pens as is and choose as shown in attached pic
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Didn't find the answer? Start a new discussion
Labels
