SOLVED!
Camera - first & second floor
Eman
Please how can I record first and upper floors as I do record the ground floor with 'create fly-through'?. My problem is that I can only record the ground floor. I mean if I select first or upper floors and set the cameras in first floor, it always record the ground floor.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 ACCEPTED SOLUTION
Solution
Scott Boyd Turner
Eman,
you will need to set the camera height to eye height plus the elevation of the desired floor level above project zero
eg for my project. - 1550mm (typical eye height) + 4500mm = 6050 first floor
                               - 1550mm + 8700mm = 10250 second floor
Regards,
Scott
MSI Creator ZP16, i7-12700H, 32GB RAM, RTX 3070 8GB
2 REPLIES 2
Solution
Scott Boyd Turner
Eman,
Regards,
Scott
Hi Scott, thanks very much.
Eman / Draftsman
Learn and get certified!
