Can I merge my cprism_{4}'s?
JGoode
I have created a hatch in 3D using for i=1 to and cprisms...
Is there anyway that I can get them to merge so that their lines in a project2 are continuous and don't create diamonds at each crossing point?
	for i=1 to 40
		cprism_{4} mat_hatching, mat_hatching, mat_hatching, 7,
				5,          line_height,
				          0,            0,            0,     15, mat_hatching,
					10,            0,            0,     15, mat_hatching,
					 10,          hatching_width,            0,     15, mat_hatching,
				           0,            0,            0,     -1, mat_hatching
		addy hatching_space
		next i
		DEL 40
		DEL 2
		addy 10
		rotz -45
		for i=1 to 40
				5,          line_height,
		addy -hatching_space
		next i
Thanks
ArchiCAD 23
Windows 10
4 REPLIES 4
Lingwisyer
Guru
Could you take your cprism out of the loop and put it into a GROUP. Then within your loop, have:
shape[i+1] = ADDGROUP ( shape_cprism, shape )
Then after your loop have:
PLACEGROUP shape
FOR ii = 1 to 40
KILLGROUP shape[ii]
NEXT ii
Ling.
Or instead of placing the prism slats, place one big slab and then cut holes from it using your loop.
JGoode
PLACEGROUP shape
FOR ii = 1 to 40
KILLGROUP shape[ii]
NEXT ii
I tried this but I get a "Group name or group expression required at line..." error.
This is my code:
		group "shape_cprism1"
					5,          line_height,
		        endgroup
			dim shape[]
			for i=1 to 40
				shape[i+1] = ADDGROUP (shape_cprism1, shape)
				addy hatching_space
			next i
			DEL 40
			DEL 2
			PLACEGROUP shape
			for ii=1 to 40
			KILLGROUP shape[ii]
			next ii
ArchiCAD 23
Windows 10
Lingwisyer
Guru
Oh, that is due to bad syntax in the SOE. Groups need to be defined in "..." or be a variable. My bad... Not sure how to work that with an array though...
Ling.
Learn and get certified!
