Can not delete or modify curtain wall mullions
Jere
I'm using the curtain wall to model some wood panelling on the interior of a building. When the curtain is used for straight sections, there's no problems at all. When i curve the curtain wall (in plan, the whole thing is vertical) then I can't delete the mullions (vertical.) I can do anything I want to the transoms (horizontals.)
The frames are all generic frames for editing (i'll change them to invisible for my final drawings.)
Any ideas? Anyone else run into this problem?
ArchiCAD 26-5002; Windows 11; Intel i7-10700KF; 16GB RAM, GeForce GTX 1660
12 REPLIES 12
Jere
Attached is a .mod file of my project. In the image above, the wall on the right is a straight wall with the final look I'm trying to achieve (different sized, but modular wood panels.) To do this, I set up the curtainwall scheme setting to a 16" x 16" grid. From there, by deleting frame members I quickly came up with a pattern I liked. I'm trying to do the exact same thing with a curved curtainwall using the same settings (wall on left.)
David Maudlin
Jere:
I am not an expert with this tool, but I got the same results you did. I was able to delete the horizontals, but not the verticals. I was only able to delete a vertical by straightening the curved section, deleting the vertical, then recurving the segment. Yes, a workaround.
This is an interesting use of the tool.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Jere
Thanks for trying at least. With this project, the radii are large (38' feet or so)[11.5m], but with smaller radii it would be very difficult as straightening it would remove many of the gridlines.
Erika Epstein
You can instead select the vertical members of the curved wall while it is curved and set all values to zero.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Jere
What do mean set all values you zero? Which values? The mullion width and depth? Thanks for your help.
Erika Epstein
yes.
1. use marquee and Find& Select to select in one step all vert members
2. open settings box and change values to 0;Note that 'h' must be set to zero before the 'b' value or b won't change.
I changed horiz members in this same manner, don't know if that is what youwanted. This preserves the separate vert. panels if that is what is wanted. If only one panel vertically, then you can delete the horiz. frame members.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
step 2
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
result
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
I can see some logic behind not being able to delete mullions (vertical) on curved walls, the consequences are more obvious with small radii. Should the resulting panel chord (span) between the remaining mullions, or should it break where the mullion was removed? This same issue also exists for the upper and lower transom frames. Not so important (but an issue) in Jere's use, but a dilemma for a typical curtain wall system.
David
