Can't change door properties
i need help with this door setting , all my doors on the floor plan cant be changed ! i dont really know why .. when i press the properties of the door and select other types of door to change it and the OK button is not press able .. can anyone help me ?
2 REPLIES 2
Please give a suitable subject to your post to assist in future searches for similar problems.
"hello guys !! me againnn " is not a suitable subject title.
I have amended it and also moved the post to the 'Working in Archicad" section which is more appropriate.
Your door object could be locked, the wall or layer could be locked in which case you can unlock them
Or it could be part of a module in which case you must edit the door in the master file (source) for that module.
vistasp
I almost fell out of my chair.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Learn and get certified!
