SOLVED!
Can't change steps configuration or materials
JohnJay
I've tried restarting AC but nothing I do seems to help.
No material changes or even steps type changes will change the look of the steps.
I've tried overriding materials and so on.
Tried creating new steps but structure and materials stay the same
(dimensions are ok though)
Any ideas pls?
edit: added image
Is there a way to reset the tool?
AC27 | i7990x | RTX4070 | W10
1 ACCEPTED SOLUTION
Solution
David Maudlin
JohnJay:
Look at Model View Options (MVO) > Stair Options > Stair 3D and Section/Elevation > and set to Full.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
2 REPLIES 2
Solution
David Maudlin
JohnJay:
David
JohnJay
Thank you - that was it
I probably need a break...
Will add a sig before next post.
Learn and get certified!
