Can't select curtain wall in section
Don't know why, but I can't select curtain walls I've place when seeing them in section. Floor plan and 3D are fine, but is so annoying. Even if I use CMD+A to select everything, the curtain walls remain unselected. Is this an issue? or is there an option I don't know about?
Thanks
Never came across this issue but I can suggest 2 things:
1. If it is true that you are using build 3003 of AC19, then you should definitely install the latest hotfix, it has many bugfixes.
2. Update your graphics card drivers, sometimes those drivers can cause stranger issues on your screen.
Thanks for the reply!. It is very weird, Sometimes it works normally others curtain walls can't be selected at all on sections. I'll try the hotfix thing and try again.
Thanks!
