Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Cantilevered Stair
Is there a way to make a cantilevered stair in archicad using stairmaker?...or another tool?... I can make them using slabs and modeling everything manually so to speak, but it looks like such a simple type of stair (shape wise) that is surprises me stairmaker doesn't have it as an option.
I'm not sure if Cantilevered is the correct name, the stair I'm refereing to is this
JLopes
One solution involves creating two overlapping stairs and subtraction of another, but there may be other!!
|| JLopes ||
|Arquitecto |
AC26 Port | Imac | 3.5 GHz | i7 | GTX 780m | OS X
AC26 Port | Ryzen 9 5900x | RTX3080 | Win
Another option is to draw the longitudinal section of the Stair in the Profile Manager's Editor, save it as a Profile and place it. Possibly as a Beam because then you will have less problems with it intersecting with other element as might be the case with a Wall.
NandoMogollon
well, you can do it with Stairmaker, with a little trick.
The down side is the fact that you get those tread / risers unnecessary lines.
My 2 cents
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
