Design forum
Center objects (Basic)
Tz
How can I centre a door in the most simple fastest way
Thank you
4 REPLIES 4
Make sure you have guide lines and snap points turned on.
Then ...
The guide lines will disappear after the drag.
Otherwise you can draw a line, activate the snap points, drag the door, then delete the line.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Thank you
Lee Hankins
You can use special snap. I have assigned a keyboard shortcut for this if ‘s’. You will then be able to activate special snap and depending on the settings you have whether it be half, number of segments of percentage split you will draw a line between two point and the object will snap to the middle or whatever setting you have chosen.
Lee Hankins
ArchiCAD 4.5 - ARCHICAD 26UKI Intel 3010 and Apple Silicon
macOS Monterey (12.5)
That is my method as well.
AC24 / AC26
Win10
