2023-02-07 06:47 PM
Hi
Is there a way to select everything in the project and change all elements together to a new renovation status?
At the moment I select everything but only certain elements actualy change status. I have to keep selecting and changing.
Is there not a way to just select everything and have them all change together?
Thanks
Solved! Go to Solution.
2023-02-07 07:10 PM - edited 2023-02-08 07:06 AM
2023-02-07 07:36 PM
Go to the Document Menu and then the Renovation Menu and there should be an option somewhere in there to reset the renovation status. You can choose from drop downs what to do with each set of elements which are currently on each filter.
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
