Design forum
Change the sizes proportionally
mest79
I created an object with archicad20 with the size "B" locked and the other 2 sizes (A and ZZYZX) that were modified proportionally with the symbol of the chain.
I lock size "B" with script parameter lock "B"
The same object, in archicad 22, I can not change it proportionally because if I block "B" I do not have the "chain".
How can I change the sizes proportionally?
Thanks!
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
1 REPLY 1
mest79
Done!
thanks to this previous discussion
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=61888
in the Master script
if GLOB_MODPAR_NAME = "A" then
ZZYZX=A*prop
PARAMETERS ZZYZX=ZZYZX
endif
if GLOB_MODPAR_NAME = "ZZYZX" then
A=ZZYZX/prop
PARAMETERS A=A
endif
!prop = value of proportion between a and zzyzx
Architect
Didn't find the answer? Start a new discussion
Labels
