Interesting.
If I send the fill forwards / backwards then the layout updates automatically.
But if I send the wall forwards / backwards the layout does not update unless I do it manually (the same for other 3D elements).
But if I move a 3D element it updates automatically just fine.
Maybe it is because 3D elements are not expected to need display order because most of them will trim each other automatically based on building material strengths.
