SOLVED!
Circular Column visualization
Hi!
Trying to make a good documentation of this view:
Red circles are circular columns.
When I try to export this view and make a pdf file, I get this picture:
All circular columns are segmented with only few faces.
How can I increase faces of these columns to make them more smooth?
1 ACCEPTED SOLUTION
Solution
David Maudlin
Alexander:
If you select the pdf file in the Publisher, click on the Document Options... button, under Document Options select the PDF options, at the bottom of the dialog box are Resolution Options, try setting the Arc resolution to a higher dpi.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
2 REPLIES 2
Solution
David Maudlin
Alexander:
David
David wrote:
Alexander:
David
It works! Thank you!
Learn and get certified!
