Project data & BIM
Clean waLl intersections
Any one experience this before.
For some reason in 8.1 i can't get clean intersections to work properly. Never have had this problem before.
If i have a wall on Layer A-WALL-EXTR-FULL &/or A-WALL EXTR-LOW the walls look great and have the proper clean intersections. But if i have walls on layers A-WALL-INTR-FULL &/or A-WALL-INTR-LOW the will not form clean intersections. But if i change the layers to both be on either EXTR or INTR the are fine.
Can anyone help this is starting to drive me nutz.
1 REPLY 1
Check your intersection priority in the layer combo dialog box (the number beside the layer's name) : if both layers have the same number, they will intersect, otherwise non interaction...
By the way, the intersection level can be saved in a layer combo
Learn and get certified!
