Design forum
Column segment horizontal offset?
Geof Gainer
Can a column segment be horizontally offset from the other segments? Eg. a wood post eccentrically placed on its concrete base.
AC fan since v 7. Currently on AC 22 Build 7000 USA FULL, AC 23 Build 5005 USA FULL, AC 24 Build 3008 USA FULL. 2013 iMac 27, Intel Core i7, 32G ram. OS X 10.14.6 Mojave
The only way I think it can be done is to use a complex profile for the segment.
You can the adjust the origin point of the complex profile to adjust the position of that segment.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
runxel
Ace
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=69631
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
Didn't find the answer? Start a new discussion
Labels
