Parametric design
About Rhino & Grasshopper and PARAM-O.
Composite Selection Crash - GH AC20 Live Conn Win
daviddelven
Hi everyone,
AC-GH connection crashes when accessing to the "composite" component list once added the component in GH.
Any solution ?
I'm running:
Windows 10 (64bits)
Rhino 90days SR13
GH 0.9.0076
Archicad 20 (4020)
Thanks in advance
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
8 REPLIES 8
daviddelven
I found the focus problem although I can't solve it so far...
It's the composites attibute file of my *.tpl template. In other files doesn't fail.
So, now I need to find where is the bug in the attribute file. Maybe the índex numbers ? Any idea ?
It could be a bug in the file, but it could also be a bug in how the Add-In handles TPL files as opposed to PLN files. I don't really know, I am just guessing.
I will forward this report to GRAPHISOFT.
If it is a bug, I am sure they will find it and fix it (hopefully soon).
daviddelven
Hi Laszlo,
Today I will send to Akós the file.
I was examinating further, and the focus seemed the Surfaces, not the composites. In spite of that, I think it's better GS look around it.
Thanks!
Katalin Borszeki
Hi All, this is a missing fill issue on the connection add-on side. We have recorded the bug and planning to fix it soon!! Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
leceta
bravo!
daviddelven
Thank you Katalin!
leceta
apparently the bug remains in version 1.7
Yes, it still there, for my case is not only composite, but also building material node.
Please help.
Thank you
