Composite wall junctions in year 2022 and their inherited problems
ArchiMind
Hello everybody,
My question and concern are that in the year 2022 composite wall and their junctions seems to be complicated, and often needs a lot of workarounds to achieve correct graphical representation.
To be precise, many T junctions are needed to be patched with complex columns, and  my opinion is, that in big designs this can become a potentially big potential problem.
Presenting this problem, I seek advice or strategies on how do you solve this problem of composite wall and their junction.
Chers,
Stefan
Versions 13 to 25
CPU: AMD Ryzen 9 5900X 12-Core
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Very tricky situation as you have 4 wall all trying to interact with each other.
Each wall will interact with one other wall automatically - so two walls no problem.
Bring in a third wall and it will want to interact with one of the other walls - but can't with both.
The junction order will help you to decide which wall interact with which other wall.
Bring in a fourth wall and you will have a bigger problem as you may get the 3 walls to trim happily, but now each wall needs to trim differently to 2 other adjacent walls.
The junction order will help fix one connection but will then break another.
I can get close by playing around with the location of the reference lines and not using junction order at all.
But it is still not perfect.
I think 4 walls that are all different composites meeting at the same point is just too much and a complex profile column is the best option.
There is also the "Create patch object" (search for that in the reference guide) which will create a 2D object overlay that you can open and edit the 2D symbol.
That is what we had to do before we had complex profile columns.
16 REPLIES 16
Hi @ArchiMind ,in these cases i use Adjust to slab options that let me connect the wall core to the slab core and the layer finish to slab bottom, like this .,, and for complex walls I use offset modifiers that let you connect every wall layer with the appropriate opposite slab layer,
Check these videos :
https://youtu.be/MO6xb_-V7DI
https://youtu.be/mkqxLGhEbIA
AC 27 INT 5003/WIN 11
Hello @Mahmoud Qenawi,
I am not talking about the wall and slab connection. I am taking about wall to wall connection, to be precise T junction of the composite wall. 🙂
Stefan
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Can you show examples of your problems?
ArchiMind
Typical example of the pointed problem
I also played with junction order, but with no luck
Stefan
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
DGSketcher
Legend
@ArchiMind Tricky one, is it a lack of intuition on the part of the user or over expectation of software capability? 😉 I think you have to recognise the limits of the AC software to manage every possible building assembly and remember you are working with an architectural DRAWING package, not a construction robot. The use of complex columns has been a solution to these difficult junctions for a long time.
I have the same problem, the orange hand drawn part should be insulation and not concrete. The only way to solve this is to duplicate materials and give them different priorities, but this really hurts my brain.
Graphisoft should really add the possibility to deactivate automatic connection and let the user to adjust the length of each wall layer (as modifiiers do on complex profiles).
ArchiMind
Hello @DGSketcher ,
The expectation of the software is to deliver the detail that has been given. As for the approach, I am well aware of the given solution with the complex columns, but, this alone is very dangerous, especially in designing big projects. The simplicity for users is gone, and room for human error is great.
Maybe software implementation should head in direction as @henryL  mentioned: "Graphisoft should really add the possibility to deactivate automatic connection and let the user to adjust the length of each wall layer (as modifiers do on complex profiles)."
We are in 2022 now, and this kind of problem should stay in past, not prolonged with each new version. Wall is an essential tool that needs to be given a lot of attention.
Don't get me wrong, I have been using Archicad since 2009, I even made the company where I work to switch from AutoCAD to Archicad, but when I have to deal with this kind of issue, it makes me lose time, and strength to be productive. All my critique is based on loving the software, and seeing its potential to grow even better 🙂
Stefan
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Hi @ArchiMind , I see your case can be solved in Archicad just some fixes, first one of the RC walls should invert it’s reference line then intersect together, second the horizontal  and vertical masonry walls should be adjusted to the outer edge of RC walls, try this it may help.
