Concealed / hidden door object
I'm trying to find a concealed / hidden door object, but can't find one. Does anyone know if there is one?
Mac OSX 13.6.4 | AC 26 INT 3001 FULL
2 REPLIES 2
Miha_M
For 3D representation you could use the default library door, you'd need to play with the reveal settings to get the desired result. Here an example I made with a few clicks.
I sadly don't have any solution if you are looking for an element with dedicated BIM values and accurate 2D details.
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
but can you get it like that from both side? I think this is the main problem. To get the relaeve so, that it is hidden from both sides.
