Design forum
Cone showing up as pyramid
I crudely modified an office chair from the AC 18 library to look like a barber's chair. The base is supposed to be a shallow cone, but it shows up as a pyramid .
The relevant script is:
!!--Cone Base
MATERIAl gs_frame_mat
ADDY 0.20
CONE 0.10,0.30,0.06,90,90
DEL 1
Does anyone know what I'm missing?
1 ACCEPTED SOLUTION
Solution
There are a few commands that affect the smoothness of cylindrical elements.
RADIUS
RESOL
TOLER
One of these has probably been set to a low value in your script.
Try 'RESOL 36' before your cone to reset to the default value.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
2 REPLIES 2
Solution
RADIUS
RESOL
TOLER
Versions 6.5 to 25
That did it. Thank you.
Didn't find the answer? Start a new discussion
Labels
