Design forum
Construction Joints / reveals: how to model?
JasonBarish
Does anybody have any good suggestions on how to model reveals (ie construction joints in concrete or stucco) in walls? The problem I'm having is that the using the old long skinny niche trick doesn't turn corners and leaves little pieces at intersection. Is also a pain to make horizontals.
The results of the log wall method is really all I need, but my joints are not evenly spaced, and I also need verticals. Not about to spend $200 (!) for the joint maker untility. Seems like there ought to be a better way to do this. Any tips much appreciated.
BTW I'm on 7 still, not 8.
11 REPLIES 11
Richard Morrison
Try the Trussmaker tool. (Really!) You can draw lines in elevation pretty much wherever you want, convert to a VERY skinny truss and it looks pretty good in a model, even though the reveals project out, rather than in. You can't really tell.
Of course if you upgrade to 8, you could use SEOs and do it "right".
Richard
"The Kitchen Architect"
http://www.richardmorrison.com
AC24 (since AC6.0), Win10
JasonBarish
Thanks for the Tip, Richard. Am doing a pretty high-resolution image and the corners are visible. Truss method might be ok w/ post work in photoshop. For that matter, I could just make my niches of zero depth and just darken them.
Guess I'll have to try to talk my boss into spending the extra $,$$$ to upgrade to 8. Am sort of dissappointed that AC doesn't have a simple method for this... seems like a common modelling operation.
Richard Morrison
Jason:
Trust me, if you make a 1" high x 1/8" thick, dark grey band, tight to the wall, you won't be able to tell if it's recessed or projecting, even at a very high resolution, unless you're zoomed in very close.
Richard
Shouldn't be disappointed when using an older version of the software. 😉 AC does have a simple method for this: SEO in 8.1 with Trussmaker, as Richard has said.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6, iMac Pro
bill shorten
if it's just an image you're after then do it with a material assignment
use the alpha channel as a bump map
vertical joints will obviously only work if they are regularly spaced as per your texture
Matthew Lohden
The upgrade to AC8.1 is a HUGE improvement. It is money very well spent.
Matthew Lohden
Consultant, SF CA
MacPro 8core 32GB Radeon 5870
OSX 10.8 Mountain Lion, XP32, Win 7x64
Aussie John
In my experience CJs arent always equally setout and can need to be individually placed. Hence alternative is to make a library part- an object can show a vertical line (or two) in 3d or if you need to model it create a window which back fills the wall materials leaving a little rebate.
the GDL scripting of the first option is pretty simple
Cheers John
[/size]
Amanda Mason
We use RevealMaker, which you can find at objectsonline.com
Dave Brach
I would like to revisit this question. I always used small slabs with SEO to do this, but recently thought that the "opening" tool might work better.  It seems to work OK, but I'm having 2 problems:  first, in plan they show up in a way that I do not like and it's impossible to turn them off because they are a part of the wall;  second, they don't seem to want to wrap around wall corners?  I think that maybe just using SEO to create reveals is better.  How do other people do this?Screen Shot 2021-09-23 at 10.02.08 AM.pngScreen Shot 2021-09-23 at 10.01.55 AM.png
Dave Brach/architect
Salt Lake City USA
www.brachdesign.com
AC24 MBP OS Catalina 10.15.7
2.6 GHz 6core intel core i7 16 GB RAM
Radeon Pro 555X 4096 MB
Intel UHD Graphics 630 1536 MB
You could also simply place Beams for the reveals. The Intersection Priority Number of the Beam's Building Material should be high enough so it cut the Wall skins.
This is a simple solution because Priority-based Connections are automatically created between Walls and Beam when they collide in 3D (it is actually an automatic SEO performed internally by Archicad).
Then you can place those Beam on a separate Layer which you can easily hide in various Layer Combinations so only the reveals cut by them are visible. You can also make their Layer wireframe so the result of their cut is visible even when the Beams are displayed (in wireframe).
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Eduardo Rolon
Using the opening tool for the corners you will need to attach the other wall to to opening, then it will clean.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Didn't find the answer? Start a new discussion
