Parametric design
About Rhino & Grasshopper and PARAM-O.
Converting text string to a surface attribute
I placed a surface attribute node, and then read it's contents into a panel.
I'd like to put that panel into an object's surface attributes.
Is it possible to script or deconstruct the surface attributes somehow in order to 'generate your own' modifications to a surface attribute?
Perhaps using python..?
Thanks.
0 REPLIES 0
