Design forum
Creating holes in a wall
bouhmidage
Hi, i always encounter this problem in the design process,
making wall recess don't always give a clean result in floor plan, i used several methods, using niches, column / beams with a higher material priority,
in this exemple i used a column,
is there a solution for that ?
Archicad 23
Windows 10 professional
5 REPLIES 5
Rajesh Patil
Hi, do send 3D view of this wall n door area. Any plaster surface you are willing to show on as outer skin of wall?
Rajesh Patil
AC 09-25 | INT | WIN10 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Yes i'll need to add a thin plaster skin later
Archicad 23
bouhmidage
Here is à sketch, i’m not in office tokay
Archicad 23
try this Option-1 :2021-09-12.png
Option-2 : Define new door with two unique ID's Wallhole & Wallniche.
Rajesh Patil
Rather than SoE-ing, could you instead us a Wall Niche?
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Didn't find the answer? Start a new discussion
Labels
