Custom CMU Blocks
Hi everyone,
First time posting here, but I have a modeling problem I need solved and not sure the best way to go about it.
Trying to create a new cmu wall type with a specific wall pattern. We are using the angelus hi-lite mark I cmu block. It has a triangular extrusion on one face.
Now is this possible to create a wall type, so I can draw a wall like any other but with this type of cmu block?
2 REPLIES 2
Nader Belal
Mentor
Hi Rivera89,
Unless you will model the whole building to US LOD400, which is quiet extreme I don't think that you have to consider modelling every independent block.
But what you can do is to give it the thickness of an equivalent CMU with a specific line type on on of the wall sides to accommodate those triangular faces, and a texture that have this particular effect on rendering.
Nader Belal
Mentor
Also, if you intend to create some details (no the whole building)
You can model your CMU model with Morph tool
Learn and get certified!
