Custom Door Leaf Materials
Guru
Hi all,
Is it possible to get a Custom Door Leaf to use the materials listed in the door settings?
Using the same Material Parameters as the default Leafs does not seem to work probably due to them not being pulled through the Calls.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
This was discussed just a little while ago.
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=27956
Basically the custom door leafs use the materials set when they are created and they can't easily be user defined.
It is possible but I am not sure it is worth it.
Guru
Whelp. Not sure how I did not find that thread. Should probably delete this one...
