Design forum
Custom Door Panel Behind Door Frame
G Ahern
Good Day
I have an issue where I have created a Custom Door Panel**, but when I use it, it places itself +/- 4' behind my door frame.
(** create using slab, etc.. save as Custom Door Panel)
I have checked the door settings and cannot find any place that seems to control where the panel sits.
(it shows correctly when I change the panel to be a standard Archicad panel...)
Any ideas?
Thanks in advance
Gary J Ahern, AIA
AC 19 - Windows 10(64 bit)
Dell Precision M6800
FAILURE IS NOT AN OPTION! It comes bundled with the software.
Focal Point Design
1150 El Camino Real, #200
Menlo Park, CA 94025
(650) 326-2800 phone
www.garyahern.com
1 REPLY 1
Lingwisyer
Legend
Zero elevation is recognised as the outside face of any door / window when they are save out from the floor plan. Anything below that will project from the face of the door, and anything above will be recessed. I am assuming that when you modelled your door, you had an element elevation set.
Ling.
*Note: was pretty sure that was how it was, but not I cannot replicate it. It is centring the leaf no matter the elevation...
Win10 | R5 2600 | 16GB | GTX1660
Didn't find the answer? Start a new discussion
