The only bit of GDL code I know of that affects schedules is GLOB_CONTEXT=6
I use it for my electrical objects so that they do not rotate in the schedule.
if GLOB_CONTEXT = 6 then
SYMB_ROTANGLE = 0
endif
Also it can be used to show (or not) window shutters, casings, trims, etc.
GS seem to use this in their window objects.
But unless you have used this in your script I can't see this is the problem.
Do you have the correct sub-type selected for your door?
If you have it as a 'wall opening' you can still place it as a door but it will not schedule.
