Design forum
Custom rail post, slanted
Titiriga
I created a custom rail post using a morph, and used it with a rail that is supposed to have a slanted profile. I set the specific angle in the Segment Slanting box, from Segment Settings, but the post remains vertical. The other parts of the rail conform to the set angle, but the custom post doesn't. If i change the custom post to a built in one (even tough its not what i need), the angle setting behaves correctly, the problem seems to be with the custom post only. Is there something that i can do about it?
Thank you.
1 REPLY 1
AZain29
I have the similar problem with custom rail post. but my problem i the custom rail would not set to the height setting, just like stuck on that height. But if i change the rail with the Archicad rail, the height rail show correctly.
Waiting for solution.
Thx.
