Custom window/ door marker shape
Hi all,
we're trying to give the window and door markers a different shape and are having trouble working out how to do this.
We'd like to alter the marker from the built in regular hexagon shape, to be a flattened hexagon as in the attached image. Is this possible? I'm assuming it will require some GDL alteration which I have little to no experience of!
Many thanks in advance
1 REPLY 1
David Maudlin
JoeyCAD:
You can use a Label on the door (Label Selected Elements). Try the Door Window Label 19, Custom Settings > Label Geometry > Frame Shape > Pointed Rectangle 90˚.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Learn and get certified!
