Cutting a section onto a Detail marker made on a plan
Polar Bear
Hello All,
Beginner question,
I have created a details marker (call out) from a plan, the kitchen
In the detail window, i am drawing a section cut line. When i go into the section, nothing is there ???
Does it mean that we cannot cut sections from call outs?
Thank you.
Kind Regards
pb
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
qbic-ft
the detail tool generates a 2D version of the 3D objects. Insert your sections into the 3D plans.
qbic-ft
Polar Bear
Thanks a lot. Coming from Revit, i got confused here.
Thanks!
Archicad 25 - 5010
