Defining a surface
JGoode
Hello,
How can I define a surface in my object?
I have a specific colour that I want as RGB values but I'm not sure how to incorporate that into creating a surface.
Any help would be much appreciated
Thanks
ArchiCAD 23
Windows 10
3 REPLIES 3
define material 😉
RGB is defined in %(0-1) not 0-255
Piotr
JGoode
Piotr wrote:
define material 😉
Piotr
Ah I worked it out but couldn't find the "tick" to show. Bit annoying that RGB is defined as a % and not the standard 0-255.
Thanks
ArchiCAD 23
Windows 10
befor use You have to add in 3d script:
material "declared_name" (in quotes for inline defined one - the inline defined atributes have negative indexes BTW)
When I do any producers GDL content I do a switch to use the predefined finish or the override
if finish_switch then _mat="declared_name" else _mat=parameter_name
in 3d script:
material _mat
Piotr
