Defining materials in a macro?
Hi everyone,
is it possible to gather general material definitions to a macro object and call them to object files by using PUT and GET commands?
I've tried this method but have gotten many different error messages such as "incompatible table parameter dimension" and "error in parameter buffer command".
Does anyone know what these messages mean? It would also be great to hear what is in your opinion is the best way to deal with repeating material definitions.
Thanks in advance for any advice concerning this matter!
3 REPLIES 3
David Maudlin
Daery_des:
You can also post your query here: GRAPHISOFT GDL Center > Forums, it was set up for GDL issues.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David Maudlin,
thank you for pointing the other GDL forum out to me. I already got some excellent advice about material definitions from there.
David Maudlin
Daery_des:
Great to read that it has helped you.
David
Learn and get certified!
