Does there exist: "prism" top, bottom, side and end material
Hubert Wagner
Hello :
Is it possible to create a GDL object similar to PRISM_ with parameters defined for : top, bottom, side and end?
Regards : Hubert Wagner
David Maudlin
Hubert Wagner:
Yes, for top, bottom and side material (end material implies a rectangular shape, this command, like Prism_ command, is for any polygonal shape) in the GDL Reference Guide see: CPRISM_ command. There is also a BEAM command that gives the material options similar to a Beam.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hubert Wagner
Hello Mr Maudlin :
Thank you for the beam tip. I've tried this and it works well.
(Student)
