Design forum
Does there exist: "prism" top, bottom, side and end material
Hubert Wagner
Hello :
Is it possible to create a GDL object similar to PRISM_ with parameters defined for : top, bottom, side and end?
Regards : Hubert Wagner
2 REPLIES 2
Hubert Wagner:
Yes, for top, bottom and side material (end material implies a rectangular shape, this command, like Prism_ command, is for any polygonal shape) in the GDL Reference Guide see: CPRISM_ command. There is also a BEAM command that gives the material options similar to a Beam.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Hubert Wagner
Hello Mr Maudlin :
Thank you for the beam tip. I've tried this and it works well.
(Student)
Didn't find the answer? Start a new discussion
Labels
