Hi Kristian,
I get the 'default' orientation values as shown in the Compatibility Options.
I am sure it used to also show the 'Custom' values (if you changed them), but no longer does this in 22.
It only seems to work when there is no parameter for 'ac_OpeningSide' I have never been able to get any use out of that parameter.
It must be deleted which can mean you have to change the subtype to just "Window (Wall)" rather than "GS Window Opening".
I assume by 'Local Standards' they mean the orientation / reference side for doors and windows as set out in the GDL manual from page 549 (version 22).
