2020-03-12 12:30 AM - last edited on 2023-05-24 10:41 AM by Rubia Torres
Solved! Go to Solution.
2020-03-13 02:18 AM
2020-03-12 08:56 AM
2020-03-13 12:00 AM
Christophe wrote:Hi Christophe! It's the width of the door, I have attached a photo. As you can see my width is 1440mm but in the dimension marker the number is less 56mm. The dimension marker number will be changed in response to whatever number I put it for width.
Hello Anh le,
Do you check about which kind of dimensions you are talking about ? One of the first door parameters deals with it. There are 5 or 6 different ways to input door dimensions.
2020-03-13 02:18 AM
2020-03-13 04:26 AM
2020-03-13 04:59 AM
Anh wrote:
I am just starting so have a lot to learn.
