Door leaf closing onto frame? [not solved]
JohnJay
Hopefully something simple I'm missing. I previously worked with AC13 and 20 and when creating doors there was an option to position the door leaf forward of the frame to give the illusion that the leaf closes onto the frame, the way nearly all uPVC doors do here in the UK.
I can't find that option in either AC 23 or 24 (only flush or rebate is possible). Maybe because I'm using Solo?
AC27 | i7990x | RTX4070 | W10
1 REPLY 1
JohnJay
Bumping this as I still haven't found a solution.  See attached - the door leaf should be proud of the frame to match the windows
