Door not showing in plan
cadsph
I've inserted a door, but it's not showing in plan view, but I can see it in section.
please see attached.
I've checked the layers - but I'm not sure if it's a setting in window elements?
Miha_M
Take a look into Model View Options, you may have "show opening only" activated for your saved ground floor view. The exclamation mark in your section title indicates that it doesn't show the assigned view settings.
| Archicad 4.55 - 27
4 REPLIES 4
Miha_M
| Archicad 4.55 - 27
Thanks Miha
Legolegend
Or it could be the wall that the door is in.  If you have the floor plan display option of the wall set to 'Outline only' then change it to 'Projected'
