SOLVED!
Door representation 2D Help
matleonii
I'm new at ArchiCAD so i'm still learning what i can do in the software. I would like to know if i can make the 2D door look like this one i used to draw in autoCAD. Notice that the door itself is closed and the dashed line shows it's opening path and end point. I figured how to do both of this things, but not simuntainially. Is that possible? Hope to get some help. Thanks
1 ACCEPTED SOLUTION
Solution
felcunha
Yes it's possible.
Go to the model view options of doors, windows and roof openings symbols, and you'll be able to choose this representation settings.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
2 REPLIES 2
Solution
felcunha
Yes it's possible.
matleonii
felcunha wrote:
Yes it's possible.
That was helpful! But I was unable to show the door handle. I could only display it on projection mode but apparently the model view settings affect only the door's symbolic view.
