Door swing in projected mode ARCHICAD 22
can someone send me script "shwswing" step by step to show swing opening in projected mode?
Thanks in advance
1 REPLY 1
Post moved to the relevant section - please try not to post everything in 'Archicad+'.
The 'Projected' mode does not use the 2D script of the objects, so you will not see the door swing.
It is simply a projected view of the 3D script.
I guess you could script an ARC or something else in the 3D script, but you will see it in al 3D views not just the plan.
So maybe try using ...
if GLOB_VIEW_TYPE = 2 then
ARC ....
endif
This should limit the arc to just floor plan views.
I am not sure if this will work with the 'Projected' mode though without trying it (which I haven't done).
Learn and get certified!
