2012-08-31 09:55 AM
2012-08-31 01:10 PM
2012-08-31 02:46 PM
2012-09-01 04:34 AM
Greg wrote:When you have entered Editing mode for the Curtain Wall, select the window panel that you want to be a door, then open its settings and under Panel Type and Geometry is a pop up list of various panel types including doors. A single Curtain Wall can have windows, solid panels, doors. The Curtain Wall tool works a bit differently than the other tools, so takes some learning/experimentation.
It looks like you used two separate curtain walls adjacent to each other to create the windows and the door. If I understand the way the panel designations work, you can only have two different panel styles. This plus a transom over the door requires two separate curtain walls. Am I correct?
2012-09-04 11:52 AM
2012-09-17 03:19 PM
2012-09-17 03:41 PM
2012-09-18 04:39 AM
Greg wrote:The lines should disappear in Section/Elevation windows, or if you change the 3D Window to Internal Engine Hidden Line, or Shaded with Contours set to Best.
I see there are joints in the vertical frames at each horizontal. Is there a way to eliminate that line so the model looks more like a real storefront, with full-height verticals?
Greg wrote:I don't think you will get a clean mitre, but will butt the end of the horizontal to the vertical. Try setting the 2 adjacent horizontal parts (door sill and glass sill) to Connection Priority 10, and the vertical to 15 (the vertical Priority is higher than the horizontals', which are equal). Depending on the other parts' Connection Priority, other settings with the same relationship may be less disruptive.
Also, I played with the priority slider, and the intersection became mitred, but offset. I tried playing around with the intersection of the horizontal and vertical pieces, but cannot seem to get to a clean mitre. Any suggestions?
2012-09-18 05:51 AM
Greg wrote:You could also try the Modular Joinery object. It's now available to subscribers on BIMcomponents. The object can be used for an almost infinite range of windows/doors/panels. And you can place it in an ordinary wall because it's an ordinary door/window object, i.e. no messing about trying to create openings to place it into, and the object also understands that a door doesn't necessarily require a frame beneath.
I have a storefront system with doors as the end panel of multiple window panels, with a concealed hinge. This means no additional frame to carry the door - it is part of the window system.
I don't find anything in either the window or door storefront libraries that allows me to make one of the windows a door, or select the number of panels on either side of a single door.
2012-09-18 08:51 AM
