2021-11-08 01:56 PM - last edited on 2023-05-24 09:42 AM by Rubia Torres
Hi there!
I am trying to model a double asymmetric door with a transom.
The trick is the panels don't have the same style and the transom neither.
Kind of the same as in the image but without the frame in the middle.
How would you do that?
Thanks a lot for your help!
Best regards,
Mathieu
2021-11-10 02:52 PM
I would just modify my doors code to do so, but you may just need to save a custom door.
Or look at the ci tools I am pretty sure their doors can do that.
2021-11-11 04:05 AM - edited 2021-11-30 02:37 AM
Open the Double Door Asymmetric and in the Master Script set gs_door_transom to 1. Save as new object.
Is not perfect, but works with most doors.
Ling.
Win10 | R5 2600 | 16GB | GTX1660 |
2021-11-29 01:19 PM
Thanks for the tip!
Thought it would work and even tried to download another door from Archicad 22 since I didn't succeed with 24 but it still doesn't work 😞
Many parameters are greyed out after the box "gs_door_transom" checked
Is there a special way to do that?
Thanks
2021-11-30 02:33 AM
Change in the Master Script.
