Dragging sets from View Map to Layout Book requires moving and adjusting
4hotshoes
I was wondering if there is a way to have the plan automatically drop into the center of a sheet layout from the center of the plan rather than the bottom left corner of the plan?
Also, If I change sheet sizes from 8.5" x 11" to 11" x 17" or 24"x36" to 30"x40", the sheets start from the bottom left corner, which requires a manual adjustment of every layout. I would like the option for all sheets to drop in from the center of the sheet. Is there a setting for this? or is it the way I created them?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
Lingwisyer
Guru
Regarding the layout origin:
https://archicad-talk.graphisoft.com/viewtopic.php?f=30&t=62515
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=61872&hilit=layout+origin
Learn and get certified!
