It is possible that your non-standard installation location is the problem - perhaps all of the ED data was not installed because of that, or ED cannot find it.
Look inside your ArchiCAD program folder > Add-Ons > EcoDesigner. You should see the attached. The usage info and more is stored in one of the localized folders. If they are all there, and each folder has 6 XML files in it, then EcoDesigner may have an issue with finding those folders if AC has not been installed in the standard location.
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
