EPS direct from ArchiCAD
Ben Odonnell
I have been wanting this option in ArchiCAD ever since I satrted using it.. Am I the only one??
Vote away
Ben O'Donnell
You should add another choice, never use/need EPS output.
stefan
In windows, You can print to file to a Postscript printer and rename the *.prn file into *.ps. Voila. A PS-file. This is usable in most Vector-Illustration software.
And I think you can do the same with PDF-files.
I'm not sure why you would need a dedicated tool.
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
I have been using it recently as a PDF takes forever to render in PS. The EPS loads in quick and gives a nice sharp result. Esp with OS maps.
Mark B
