Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
Ecodesigner Problem
muril00ng
Hi folks!
I have a problem with Ecodesigner for AC 13. When i open the option "Facade Shadings", the AC shows anything in the window (look at the added image), also i didn't have a option for Activity, that shows "Missing".
I saw here in forun a similar problem (http://archicad-talk.graphisoft.com/viewtopic.php?t=33306&highlight=ecodesigner) but i didn't obtain the solution.
My ArchiCAD 13 is a portuguese version.
Thanks!!
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
4 REPLIES 4
Using my directions in the other thread, did you look in your Add-ons folder to see what EcoDesigner data files you have? Is there an INT folder with the files shown in this screenshot?
One of the forum moderators
muril00ng
I have these 6 files in the "INT".
I'm try to rename the folder, in case of "USA". But it's not works.
What am i do?
Murilo Noleto
USA would only work if you have a US license.
Go here:
https://upgrade.graphisoft.com
to find out what kind of ED license is stored on your key. You should see something like the screenshot below for my license, showing that I have a USA version.
I would guess that yours says INT, but perhaps there is a POR or BRA version. If you see POR, e.g., try copying the folder and naming the copy POR. You will have to restart ArchiCAD to find out if it makes a difference.
muril00ng
Thank you Karl for your atention, you are fast!
I solved the problem!
Murilo Noleto
